Depends on the ESC. How much voltage or how many cells (usually meaning NiCd or LiPo) is it rated for? In all likelihood, you will be OK using that 30A controller, but you should check its specifications first. Remember, the ESC passes the voltage to the motor directly. The most important consideration is how your motor will respond with 12V or whatever voltage your power source provides.O
Any harm in connecting the 12 V directly to the ESC?
Yes. There are many 555-based circuits. Check Bill Marsden's blogs here. Or, just search on RC servo controller. An MCU will also work, but the hardware pwm functions may not get to the 50 Hz needed for model servos. I have used somewhat higher frequencies (e.g, 120 Hz), which was attainable. You can also just code the pwm in software.Is there some simple circuit I can build to make the PWM to the ESC?
I guess I am a little bit rusty here, but what exactly does the ESC do. You say it supplies the voltage to the motor? I was thinking more in the line of the ESC being a current source and supplying "x" amount of amps, depending on the servo-signal it gets. Would you mind explaining the operations of the ESC?Depends on the ESC. How much voltage or how many cells (usually meaning NiCd or LiPo) is it rated for? In all likelihood, you will be OK using that 30A controller, but you should check its specifications first. Remember, the ESC passes the voltage to the motor directly. The most important consideration is how your motor will respond with 12V or whatever voltage your power source provides.
