How can I modify this antenna to perform better?
Discussion in 'The Projects Forum' started by foolios, Dec 8, 2014.
  1. foolios
    Thread Starter Active Member
    Feb 4, 2009
    160
    I was wondering if it would be a simple matter to add some copper wire to it's length and then drill a hole in the plastic cover so that it will help keep the extra length straight up.
    Will something like that work? If so, do I add extra wire length to the little wire at the top, add copper to the silver metal shaft and lengthen it, or lengthen the thicker wire at the base?
  2. Lestraveled
    May 19, 2014
    1,957
    1,218
    Adding extra length to this antenna will just de-tune it. If you want more performance, buy (or build) a high gain antenna that is the same frequency as your router.
    Dr.killjoy and KJ6EAD like this.
  3. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    He is right..
    You could also make the antenna directional to help with better signal strength.. Let me find the vid from youtube..
  4. foolios
    Feb 4, 2009
    160
    Thanks, you two, for the info.
  5. GopherT
    Nov 23, 2012
    6,314
    4,032
    Or, you might just try recreating the exact conditions that allowed you to get 5-bars of signal that one time...
    http://xkcd.com/1457/
  6. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
  7. foolios
    Feb 4, 2009
    160
    Wow, now that's saweet!
    Thanks for the posts! :D
