how can i make BCD flip-flop down counter *urgent*
Discussion in 'Homework Help' started by mohsen, Nov 8, 2010.
  1. mohsen
    Thread Starter Active Member
    Oct 24, 2008
    37
    how can i make BCD series flip-flop down counter
    i have made the counter count 0-9, how can i make it count 9-0
      File size:
      26.5 KB
      163
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    Just for the record, this isn't a BCD counter. It is a binary counter hooked up on a Bin-to-BCD converter / 7-seg driver.
    In order to count down from 9 to 0 and use only FFs to generate the numbers, you need some way to load number 9 paralelly at the start of each count cycle. But in an asynchronous circuit that doesn't seem possible.
    If anyone has a different opinion, I would gladly hear it.
    If I where you, I would consider using a synchonous counter like the "down counter" in this page http://www.allaboutcircuits.com/vol_4/chpt_11/3.html and find a way to implement a parallel load. This can be done with a few logic gates and four 2-to-1 MUXs. It can be a bit tricky, though. Ask further if you have more questions.
    If this isn't a theoretical exercise and you just want to build a 9-0 counter, you can simply use the 74193 IC: http://www.datasheetcatalog.org/datasheets/90/248169_DS.pdf
    It also contains a schematic for the whole system.
    P.S. Does anyone know if the T-FFs in the datasheet are set with input T=1, and thus change state in every clock cycle? No direct reference on the FF input is made.
  3. Kermit2
    Feb 5, 2010
    3,845
    963
  4. mohsen
    Oct 24, 2008
    37
    well i made this counter in the picture it count from 0-9 ^_^ so it is BCD lol
    anyway i still don't get it how to make it count the otherway
  5. shteii01
    Feb 19, 2010
    3,500
    511
    Ok, since you can do the count up, 0 to 9. Can you put NOT gates at the outputs to invert the output? 0 becomes 9, and 9 becomes 0. The overall effect is count down.
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    If NOT gates are used to invert the 0-9 count, the result will be 1111,1110,1101,...,0101
    Or in decimal 15-5. Clearly this is a no-go.
    Are you not satisfied with the option of using the 74193 IC?
