How can i make a proximity detector.
Discussion in 'General Electronics Chat' started by amruth11, Jul 6, 2011.
  1. amruth11
    May 24, 2011
    49
  2. praondevou
    Jul 9, 2011
    2,936
    489
    What exactly is the trouble you are having? :confused:
    The only thing I can tell you right away is that you have to make sure to put the capacitors drawn seperately (Vcc to GND) near the 555 and also to not extend the circuit on a too big surface.
  3. mbxs3
    Oct 14, 2009
    143
    Do you have all of the required components shown in the schematic you referenced?
  4. amruth11
    May 24, 2011
    49
    HI i have all the items needed and can someone show me how to connect it on the breadboard.
  5. iONic
    Nov 16, 2007
    1,422
    68
    If I get a few minutes I will draw this out for you.
  6. iONic
    Nov 16, 2007
    1,422
    68
    I believe this circuit will be more understandable for newbies. It is not a part-by-part layout for a breadboard. For a quick breadboard intro refer to:
    Intro to Breadboarding
    amruth11 likes this.
  7. mbxs3
    Oct 14, 2009
    143
    Make sure you observe the correct polarity of the 10uF cap when building the circuit on your breadboard.
  8. amruth11
    May 24, 2011
    49
    Thx guys for all the help and can i swap the 0.02uF cap for a 0.22pF or other caps cause i am not able to get the 0.02uF in india.
  9. amruth11
    May 24, 2011
    49
    UR circuit is very helpful thx.
  10. radiohead
    May 28, 2009
    474
    31
    you can use two .01uF in parallel for .02uF
  11. #12
    Nov 30, 2010
    16,665
    7,310
    R1, R2, and C2 form a timer circuit. The values are important. You really need to get this one right.
