How can I make a + and - 5V source using two adaptors?
Discussion in 'General Electronics Chat' started by zero_coke, Nov 15, 2011.
  1. zero_coke
    Thread Starter Active Member
    Apr 22, 2009
    294
    I have two Motorola adaptors that have an output of +5V. I need to use these two to make one -5V and the other +5V. I think each of the adaptors has two wires, one +5V and the other one is ground I believe.
  2. wmodavis
    Oct 23, 2010
    737
    150
    Hook the + of one to the - of the other. That connection will be your common. The remaining + will be +5V. The remaining - will be the -5V.
    zero_coke likes this.
  3. zero_coke
    Apr 22, 2009
    294
    Yep, worked. Thanks!
