How can I have a high-current buffer for the op-amp in Howland current source?
Discussion in 'The Projects Forum' started by Tran Binh Duong, Aug 3, 2016.
  1. Tran Binh Duong
    Aug 1, 2016
    Dear Ron,
    I mean that I need a bipolar buffer placed at the output of op-amp.
    PS: I want to make a AC Current Source based on Howland Current Source which be able to put out 1A and ±15V at up to 50Hz-10kHz.
    Mod note:
    Please don't hijack other member's thread, now you have your own.
    Our Fanatic member Ron H had not join the forum about 6 months, he may not answer your question, I will also left a link to there on the thread that you posted, if you have any question then you just post on your thread, thank you.
    This thread was split from -- AC constant current source.
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,679
    1,295
    Are the 1 A and +/-15 V requirements RMS or peak values?
    Is one end of the load connected to the system ground?
    What is the amplitude of the signal source?
    ak
