How can I get 12V DC 2A FROM 220V AC Without transformer
Discussion in 'General Electronics Chat' started by sendbad, Oct 5, 2016.
Thread Status:
Not open for further replies.
  1. sendbad
    Jan 8, 2015
    43
    OR 12V DC 2A FROM 330V DC.
  2. tcmtech
    Nov 4, 2013
    2,117
    1,753
    You use a Switch Mode Power Supply. No other way around the DC input requirement.
  3. sendbad
    Jan 8, 2015
    43
    330 V DC TO 12V DC NEED transformer
  4. tranzz4md
    Member
    Apr 10, 2015
    152
    28
    No, 330vdc to 12 vdc does not need transformer. Buck converter, buck-boost, SMPS, or even a simple resistor. Go for complexity: M-G!
    Now we do have some other problems to deal with however. I suspect that language barrier and answer shopping are the primary ones, although sheer ignorance is present, and it's the only problem this forum is meant to deal with. Please read the rules for posting on these forums, and if need be, go elsewhere on the web to discover what those words mean.
    Incidentally, you've already gotten your 12vdc, you just didn't know it.
  5. sendbad
    Jan 8, 2015
    43
    220 V AC TO 330DC
    330VDC TO 12V 2A
    I speak here about amps
    <Rude and inflammatory remarks removed -please be polite, its in the rules dc>
  6. dl324
    Distinguished Member
    Mar 30, 2015
    3,380
    652
    We can't. Transformer-less power supplies are a forbidden topic.
    You are required to read and abide by the ToS.
  7. tcmtech
    Nov 4, 2013
    2,117
    1,753
    And this will get people to work with you to solve your problem how? o_O
    I have a circuit and it would be easy to build but given that attitude you can go 'eff' yourself instead.. :(
  8. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    No nead to be rude.
    Just read the User Agreement.
    See point 6.
    In there the transformerless powersupplies are NOT allowed.
    Bertus
Thread Status:
