How can I find out the voltage of this drill?
Discussion in 'General Electronics Chat' started by Philip Walsh, Apr 3, 2015.
  1. Philip Walsh
    Apr 3, 2015
    6
    I found a hammer drill in a skip and I want to repair it. But the problem is there was no chord & plug, so I have no clue as to the voltage of the drill, I live in the UK so it could very easily be 120V or 230V. Its a Bosch GBH 2-26. I found the manual online but there is no mention of voltage which leads me to believe the drill is sold with both voltages. Is there anyway I can find out? I dont want to take a chance and wire up a plug and risk burning out the motor. It dosn't say anywhere on the drill casing anything about voltage or amrerage. Thanks!
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    First, make sure it isn't internally shorted to the case. Use an ohm meter or better, a megger. If that checks out OK, proceed. If you connect it to 120V and it is really a 230V, it won't hurt it. It will just run slower with lower power. Start with the lowest of the choices.
    Philip Walsh likes this.
  3. Philip Walsh
    Apr 3, 2015
    6
    Thanks!
  4. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,850
    1,317
    Please be very, very certain it is not a battery operated product!
    Best regards
    HP
  5. Philip Walsh
    Apr 3, 2015
    6
    Thanks....It is not a battery operated drill! Its just missing the chord...
    Hypatia's Protege likes this.
  6. blocco a spirale
    Jun 18, 2008
    1,461
    370
    Are you sure it's not a guitar?
    upand_at_them and sirch2 like this.
  7. Philip Walsh
    Apr 3, 2015
    6
  8. Philip Walsh
    Apr 3, 2015
    6
    TE="blocco a spirale, post: 841116, member: 24400"]Are you sure it's not a guitar?[/QUOTE]
    Shut up you idiot. It was a perfectly valid thread, no need for stupid answers.
    spark8217 and Dodgydave like this.
  9. blocco a spirale
    Jun 18, 2008
    1,461
    370
    "TE="blocco a spirale, post: 841116, member: 24400"]Are you sure it's not a guitar?[/QUOTE]
    Shut up you idiot. It was a perfectly valid thread, no need for stupid answers."
    Calm down you idiot, it is a joke which anyone, with a modicum of education and intelligence, will understand.... but you are clearly not in that category!
    I spent some time, on your behalf, researching the drill model when you first posted the question and I read the manual but could find no useful information to help identify the voltage of your drill.... but, I tried.
    You're welcome!
    And the word you're looking for is "Cord", but then, I would not expect an idiot to know that.
  10. Dodgydave
    Jun 22, 2012
    5,159
    772
    yes they make dual voltage versions, the 110v ac is for building/construction sites and usually comes with a yellow plug.
  11. Philip Walsh
    Apr 3, 2015
    6
    You're welcome!
    And the word you're looking for is "Cord", but then, I would not expect an idiot to know that.[/QUOTE]
    Oh...thanks! :) turns out the stator was burned out. So ill probably toss it back in the skip. Thanks anyway!
  12. Hypatia's Protege
    Mar 1, 2015
    2,850
    1,317
    You're welcome!
    HTML hash, anyone? :confused::confused::confused:
  13. shortbus
    Sep 30, 2009
    4,096
    1,692
    It's probably burned, they both had the flame turned up way too high. :)
    Sinus23 and Hypatia's Protege like this.
