How can I do away with (mic ) ?
Discussion in 'The Projects Forum' started by micron, Dec 28, 2009.
  1. micron
    Nov 2, 2009
    10
    Hello I have looked the similar threads with no luck . To start lets be claer that I am a ( newbie ) . I am working on a line following robot from a kit that I am trying to put in to a model car that I got from wal mart. I can get the robot moving by tapping on the mic. Now just guessing with my limiterd knowledge Iam thinking that the signal from the tapping on the mic is needed to start the car moving . My problem is that when I put the body of the car on the chassie I can not get to the mic to give it a tap. so is there any way that I can do away with the mic? I was thinking of maybe a switch that would pick up a signal from some where .Many thanks to any one that could help me with this . Micron thanks for your reply I have added some info I found on the part u1. an you are right I think that u5-u6-u7 are the photosensors the kit is called line following mouse an came from electronics express .an as I said really new at this an in over my head but teacher said this would be good for us. He doesn't really want a kit but would except a varyation of a kit
  2. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    This does not make much sense to me. Why the mic? Line followers normally use light and some sort of photo detector perhaps like u4..6, but these look like optical isolators.
    Spec sheet for parts would really help, can you find them, esp for U1? It may be out there but not obvious to me. Where did the kit come form? Are there any more directions?
  3. micron
    Nov 2, 2009
    10
    I have have added more info maybe this will help thanks for looking
  4. micron
    Nov 2, 2009
    10
    by the way when I turn the switch on the car just sits there till I tap on the mic if thatis any help
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    In this case, what you have is all there is. You will need to find another design made for a line follower.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    I suspect the circuit is supposed to respond to a clap.
  7. micron
    Nov 2, 2009
    10
    that's what I was thinking. but is there a way to run this without the mic?
  8. BMorse
    Sep 26, 2009
    2,675
    234
    It is a line follower which is activated by sound (clap). Those are not optocouplers they are IR LED and Phototransistor pairs (similar to picture), they are positioned to where the IR is reflected off of the line to be followed.
    From what it looks like, you can remove the mic and connect a switch to ground and pin 9 to activate it.... If you can cut the trace from where the 10K resistor (R2) connects to Q1, (but leave PIN 9 connected to the resistor), and then connect your switch there and to ground, so every time you press the switch it should activate the circuit.....
    My .02
  9. micron
    Nov 2, 2009
    10
    thank you very much !! I will give this a try
