How can I design a dc to ac inverter which will not use a transformer?
Discussion in 'General Electronics Chat' started by BharathiMN, May 29, 2014.
  1. BharathiMN
    May 22, 2014
    Hi i have planned to design a dc to ac conveter with 12vDC input and 230VA output, Please guide me how can i design inverter without transformer?
  2. Sensacell
    Jun 19, 2012
    1,184
    277
    That's like asking for an airplane without wings!
    A rocket is an airplane without wings: it's terribly inefficient, complex and expensive.
  3. ScottWang
    Aug 23, 2012
    4,933
    777
    To using an oscillator and an amplifier to amplify the voltage from 12Vac to 230Vac.
  4. R!f@@
    Apr 2, 2009
    8,792
    771
    Design H Bridge version
  5. BillB3857
    Feb 28, 2009
    2,402
    348
    So where does the high voltage come from to begin with? 20 car batteries in series, capacitor/diode voltage multiplier, etc, etc? After you get the high voltage, the H-bridge sounds like the best bet to chop it up and reverse the polarity.
  6. R!f@@
    Apr 2, 2009
    8,792
    771
    U forgot OP said VA. So It could be 1V at 230Amps :D
  7. BillB3857
    Feb 28, 2009
    2,402
    348
    WOW! I missed the VA tag. Looked at it only as VAC. I guess a dry cell wouldn't quite do it either, would it? Have an appointment to get my eyes checked.
  8. R!f@@
    Apr 2, 2009
    8,792
    771
    The Battery type is his problem.
  9. Brevor
    Apr 9, 2011
    282
    56
    The transformer is the most expensive part of a DC to AC inverter, If it were possible to make one without a transformer someone would have already done so. And they would probably be very rich.
  10. BobTPH
    Jun 5, 2013
    806
    121
    It is possible to do without a transformer (but you do need an inductor). Make a step up converter to 325VDC then use and H-bridge to invert it to 230VAC. If you can get the boost converter to run in the MHz region, the inductor could be quite a bit smaller and less expensive then a 12V to 230V transformer.
    Bob
  11. Brownout
    Jan 10, 2012
    2,375
    998
    I agree with Bob. If I took my square wave inverter apart, that's what I expect to find.
  12. R!f@@
    Apr 2, 2009
    8,792
    771
    OP did not say 230VAC.
  13. gerty
    Aug 30, 2007
    1,154
    304
    You're correct..But if he meant 230VAC, he didn't tell us how much current. So either way he left out some important information.
