how can I copy & paste from excel into AAC's table function?
Discussion in 'Off-Topic' started by strantor, Apr 13, 2012.
  1. strantor
    Thread Starter AAC Fanatic!
    Oct 3, 2010
    4,302
    1,989
    I've copied & pasted tables from websites into AAC before and it worked just fine. I just selected the text data, and then clicked the table button and AACs table function automatically recognized each cell and each row and did i perfectly. So I know it has the capability. When I do the same thing from Excel however, it doesn't work. It lump all the columns together in each row. I tried saving my document in several formats thinking it was some kind of invisible formatting issue but no luck. So what do I have to do?
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
    You could try:
    Save the Excel file as an *.html file
    View the file in your Internet browser
    Copy/paste from that file
  3. strantor
    Oct 3, 2010
    4,302
    1,989
    Yeah the result is the same. looks like this:
    (copied from HTML file)
    QTYNewark PART #DESCRIPTION UNIT COST TOTAL COST 393K5434 PCB mount 12V relay $ 2.28 $ 6.84 226R4228 RESISTOR, METAL GLAZE, 20 MOHM, 500 MW, ± 5% $ 0.12 $ 0.24 196M9178
    12V wall wart p/s for fault tester $ 13.53 $ 13.53 1070R0064TERM BLK, PCB, SCREW, 5.0MM, 2WAY $ 0.73 $ 7.30 113T9276Enclosure for the Arduino Duemilanove or Mega w/ Ethernet Shield $ 9.46 $ 9.46 113T9277
    ARDUINO UNO Board w/ Workshop Starter Kit (just buy the 25$ arduino, not the kit)
    $ 71.38 $ 71.38 213T9280
    PROTOTYPE BOARD FOR ARDUINO UNO $ 10.42 $ 20.84 389K1072TIP120 DARLINGTON TRANSISTOR, NPN, 60V, TO-220 $ 0.43 $ 1.29 101M7886CONVERTER, DC/DC, 1.5W, +1000V
    $ 183.00 $ 183.00 131K7040OPTOCOUPLER, DARLINGTON, 3750VRMS $ 7.02 $ 7.02 Total $ 320.90
    I've tried html, csv, etc.
    should look like this:
  4. MrChips
    Oct 2, 2009
    12,622
    3,451
    As far as I know, columns are separated by the | symbol.
    You have to have the same number of columns in each line.
  5. strantor
    Oct 3, 2010
    4,302
    1,989
    That's not working either.
    QTY Newark PART # DESCRIPTION UNIT COST TOTAL COST
    3 93K5434 PCB mount 12V relay $ 2.28 $ 6.84
    2 26R4228 RESISTOR, METAL GLAZE, 20 MOHM, 500 MW, ± 5% $ 0.12 $ 0.24
    1 96M9178 12V wall wart p/s $ 13.53 $ 13.53
    10 70R0064 TERM BLK, PCB, SCREW, 5.0MM, 2WAY $ 0.73 $ 7.30
    1 13T9276 Enclosure for the Arduino Duemilanove or Mega $ 9.46 $ 9.46
    1 13T9277 ARDUINO UNO Board w/ Workshop Starter Kit (just buy the 25$ arduino, not the kit) $ 71.38 $ 71.38
    2 13T9280 PROTOTYPE BOARD FOR ARDUINO UNO $ 10.42 $ 20.84
    3 89K1072 TIP120 DARLINGTON TRANSISTOR, NPN, 60V, TO-220 $ 0.43 $ 1.29
    1 01M7886 CONVERTER, DC/DC, 1.5W, +1000V $ 183.00 $ 183.00
    1 31K7040 OPTOCOUPLER, DARLINGTON, 3750VRMS $ 7.02 $ 7.02
    Total $ 320.90
    Code ( (Unknown Language)):
    1. |QTY | Newark PART # | DESCRIPTION                                   | UNIT COST | TOTAL COST
    2. |3   | 93K5434       | PCB mount 12V relay                           | $ 2.28    | $ 6.84
    3. |2   | 26R4228       | RESISTOR, METAL GLAZE, 20 MOHM, 500 MW, ± 5%  | $ 0.12    | $ 0.24
    4. |1   | 96M9178       | 12V wall wart p/s                             | $ 13.53   | $ 13.53
    5. |10  | 70R0064       | TERM BLK, PCB, SCREW, 5.0MM, 2WAY             | $ 0.73    | $ 7.30
    6. |1   | 13T9276       | Enclosure for the Arduino Duemilanove or Mega | $ 9.46    | $ 9.46
    7. |1   | 13T9277       | ARDUINO UNO Board w/ Workshop Starter Kit (just buy the 25$ arduino, not the kit) | $ 71.38 | $ 71.38
    8. |2   | 13T9280       | PROTOTYPE BOARD FOR ARDUINO UNO               | $ 10.42   | $ 20.84
    9. |3   | 89K1072       | TIP120 DARLINGTON TRANSISTOR, NPN, 60V, TO-220| $ 0.43    | $ 1.29
    10. |1   | 01M7886       | CONVERTER, DC/DC, 1.5W, +1000V                | $ 183.00  | $ 183.00
    11. |1   | 31K7040       | OPTOCOUPLER, DARLINGTON, 3750VRMS             | $ 7.02    | $ 7.02
    12. |    |               |                                               | Total     | $ 320.90
    13.
    EDIT: AHA! apparently it is working, just not in the post preview. how strange!
    Still, That took me a while in noepad putting all those extra characters in. it would be nice if it were as simple as copy & paste.
  6. studiot
    Nov 9, 2007
    5,005
    515
    Hey guys that's fantastic. Thanks a bundle I've been wanting to display tables for ages.
    1. | 1234 |Col test1|tabletest1|
    2. |123456|line2|tabletest1
  7. Markd77
    Sep 7, 2009
    2,803
    594
    I guess you could insert columns of | in the spreadsheet. Still fairly tedious.
    This little formula should do it:
    ITEM PRICE
    Resistor 0.01
    Flux Capacitor 12700.39
    PIC10F200 0.34
    I guess you have to convert the original to text if you want the currency sign to work.
    strantor likes this.
  8. loosewire
    Apr 25, 2008
    1,584
    435
    The wise men of the Forum,good job guys.
