how can I analyse a 40khz pulse by input capture in atmega16
Discussion in 'Embedded Systems and Microcontrollers' started by electronical soccer, Jun 7, 2011.
  1. electronical soccer
    Jun 7, 2011
    hello.I want to find a 40khz pulse by using the input capture in atmega16.I mean after the ICP pin receives the input,how can I achieve the frequncy of it? and is it possible to calculate the frequency?
    thanks alot:(
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Do you know how a frequency counter works? - http://en.wikipedia.org/wiki/Frequency_counter
    You will need a very accurate timing signal to be able to define a period in which to count that 40 KHz pulse. You may easily need external conditioning circuitry to make the pulse into a signal that can be used as an input to the Atmega.
    Notice that the method is to count pulses over a defined time. You seem to wish to be able to get the frequency from one pulse.
