how can i adjust the charger circuit to fully charge battery with light up LED at 1.3V
Discussion in 'The Projects Forum' started by TYYang, Apr 30, 2015.
  1. TYYang
    Apr 3, 2015
    18
    how do i adjust the resistance value by parallel rule?
  2. Ramussons
    May 3, 2013
    562
    92
    Which Resistor value?
    The equivalant value of 2 resistors R1 and R2 connected in parallel is
    Req = (R1 * R2)/(R1 + R2)
  3. #12
    Nov 30, 2010
    16,704
    7,354
    1/R1 + 1/R2 + 1/R3 + 1/R4...=1/Rfinal
    Ramussons likes this.
  4. TYYang
    Apr 3, 2015
    18
    I wish to adjust the value for R1 in order to find a suitable current flow when the battery reach 1.3V and then the LED will bright up.
  5. dl324
    Distinguished Member
    Mar 30, 2015
    3,379
    651
    I suspect you're going to find that using an LED that way will leave a little to be desired. The eye doesn't respond well to subtle changes in luminous intensity.
    It would be better to use a comparator and have the LED be either on or off when your desired voltage is reached.
    What is your intent with R1? Putting it in the voltage setting path adds some variability in the regulator output; so does your current limit resistor...
    BTW, I never liked that type of current limiting. I'd put the current sense on the input of the regulator and use a comparator to "shutdown" the regulator. If I was being really particular, I'd make a -1.25V reference so I could really shut it down.
