How can fiber optic cable work so well?
Discussion in 'General Science' started by tjohnson, Aug 18, 2015.
  1. tjohnson
    Thread Starter Active Member
    Dec 23, 2014
    618
    122
    I've read that fiber optic cable has an almost nonexistent rate of data loss that is much less than that of cable or DSL.
    I also learned in physics that when a ray of light passes through a tube with a bend in it, some of the light will be lost through refraction. This would seem to me to prevent fiber optic cables from being practical, whereas electrical signals traveling through wires don't experience this same phenomena.
    What am I not thinking of? Does the insulation on fiber optic cables not allow any light to leave the cable?
  2. BR-549
    Sep 22, 2013
    2,181
    419
    I'm no expert, but the optic cable reflections are internal and not lost.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    The process of making the cable from glass tubing creates a really clear inner core and a really good mirror sheathing it.
    The optics has also improved radically over the decades. We now have fiber amplifiers that will amplify the signal +30 db or more, to the point the output requires laser filter glasses.
    The spectral purity as also gone through roof. The early transmitter could do a fraction of a Meg (they were LEDs), now (because each laser is very pure with no sidebands) we can stack 40 channels at 40Gig/sec on one fiber. I used to be a tech that manufactured fiber optic gear (telephony before that). And this was 15 years ago, I suspect it has only gotten faster and better.
    tjohnson likes this.
  4. Lool
    Member
    May 8, 2013
    117
    12
    Wendy is correct. Total internal reflection is an essentially lossless phenomenon, and there is no refraction out of the glass (or core) when the angle of light rays are shallow enough (below the critical angle). The primary losses in silica glass fiber are OH absorption from very tiny trace amount of water molecules, Raleigh scattering (bouncing off SiO2 and other dopant molecules basically) and and a tail from a far infrared absorption band for the glass molecules.
    The Raleigh scattering is higher in the blue-ultraviolet region and decreases (wavelength to the -4 power) as we go into the infrared communication band. The infrared absorption is high in the far infrared and decreases we go up in wavelength th the near infrared communications band. The lowest loss occurs at 1550 nm, right where Er-doped fiber amplifiers naturally amplify light (how fortunate), and the OH-absorption peak around 1450 nm creates another local minimum loss wavelength at 1310 nm (still higher loss than at 1550 nm), right where the glass's chromatic dispersion is zero (how fortunate). Also, with waveguide design, the zero dispersion wavelength can be shifted to the 1550 nm band (again, how fortunate).
    There are no words that can adequately describe the amazing progress that man has made in making silica glass fiber just about as perfect as it can be. There are no words that can adequately describe the amazing aspects of nature that can provide us with a practically lossless and dispersionless transmission medium.
    Cyberduke likes this.
  5. tjohnson
    Dec 23, 2014
    618
    122
    Upon further thought, I guess that's not true, given the inductive properties of wire coils?
  6. Lool
    Member
    May 8, 2013
    117
    12
    Actually, it is not the inductance, although you are thinking on the right track now. Losses like this would be radiation losses. Also, resistive losses in wires dissipate energy.
  7. tjohnson
    Dec 23, 2014
    618
    122
    Right, I forgot about that. I knew that the energy loss caused by resistance would weaken the signals, but not that it could cause some of them to get lost. But I suppose that the second logically follows from the first?
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    If there were such a thing as room temperature superconductors I suspect fiber would have competition.
  9. Bonnie Smith
    Jun 26, 2015
    Yes, only weaken the signals, and we can use the fiber amplifier to enhance the signals.
  10. Lool
    Member
    May 8, 2013
    117
    12
    That would be a great thing for power transmission, but for communications transmission, it would only mitigate one of the many limitations of wire based transmission. Bandwidth limits due to modulation limits and dispersion are important factors. Further, optical fiber diameter is much smaller than even the smallest coax cable designs.
  11. tjohnson
    Dec 23, 2014
    618
    122
    Yes, but that's not what I was asking. Since we know that energy loss due to resistance weakens the electrical signals traveling through a wire, would this mean that an extremely small percentage of the signals become so weak that they get lost completely? I'm trying to figure out what causes data loss in electrical wires (not really talking about fiber optic cables anymore).
  12. GopherT
    Nov 23, 2012
    6,314
    4,032
    Your original question was about data loss, now you are talking about power or signal loss.
    Data loss can happen from a weak signal but more likely because of extra bits introduced into a data stream that screws up the transmission. Power fluctuations/spikes/radio interference/ .... Can effect electrical signals whereas fiber is shrouded and suffers no similar issues. That is, stray photons do not jump into a glass fiber like capacitive or inductive effects can cause electrical fluctuations into a copper cable.
  13. fiberstorejames
    Aug 5, 2014
    18
  14. KeepItSimpleStupid
    Mar 4, 2014
    1,276
    224
    I saw tags attached to a cable in the underground parking lot in a building that said "Caution - Lightwire" . Took me a few moments to realize it was a bundle of fiber optic cable.
