how can convert input sinusoidal wave to output square wave
Discussion in 'General Electronics Chat' started by outstanding student, Nov 5, 2008.
  1. outstanding student
    Nov 5, 2008
    how can convert input sinusoidal wave to output square wave?
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. KL7AJ
    Nov 4, 2008
    2,047
    295
    Let me count the ways:
    Schmitt Trigger
    Comparator
    Overdriven amplifier
    Threshold driven flip flop
    Clipper/differentiator/bistable multivibrator
    Odd harmonic multiplier/adder
    Shall we continue?
    Eric
  4. KL7AJ
    Nov 4, 2008
    2,047
    295
    However, probably the simplest and cleanest would be a simple comparator.
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
  6. outstanding student
    Nov 5, 2008
    i forgot to mention that i should use diode circuit only
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
  8. outstanding student
    Nov 5, 2008
    Thank you Bill Marsden for your reply
    but the final output has some slope. i need exactly square wave.
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    Then you can't use diodes. You want exact, it needs to be active (ie, gain).
    Diodes clip the top and bottom off. You'll find all square waves have some slope, it is a function of frequency response. The actual term is slew rate.
  10. KL7AJ
    Nov 4, 2008
    2,047
    295
    You can get a little sharper edges with Zener diodes, but they still aren't perfect....and they tend to be slow.
