How can a fm-phone signal be produced in a transmitter
Discussion in 'Homework Help' started by bwd111, Aug 23, 2013.
  1. bwd111
    Jul 24, 2013
    117
    Stuck on this question first I was thinking by using a balanced modulator then by feeding the audio directly to the oscillator made more sense to me
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Take time to reflect on when a balanced modulator is used in radio communication. Is it used to produce FM?
    Was the answer "by feeding the audio directly to the oscillator" one of the choices you were given?
  3. vk6zgo
    Jul 21, 2012
    677
    85
    This won't affect your answer,but there are several older,pretty much obsolete, methods of obtaining FM which do utilise a balanced modulator as part of a quite complex system,so if you look up some old references,you may be led astray.
