How calculator calculate?
Discussion in 'Embedded Systems and Microcontrollers' started by RRavi, May 4, 2016.
Thread Status:
Not open for further replies.
  1. RRavi
    May 4, 2016
    10
    How calculator calculate so fast add sub multiply divide so fast?
    Is there any look up table in processor of calculator?
    what is adder circuit?
  2. recklessrog
    Member
    May 23, 2013
    346
    102
    It's all done with smoke and mirrors.
    DNA Robotics likes this.
  3. RRavi
    May 4, 2016
    10
    how he is doing?
  4. RRavi
    May 4, 2016
    10
  5. JWHassler
    Member
    Sep 25, 2013
    204
    34
    Look up the history of the CORDIC algorithm
  6. RRavi
    May 4, 2016
    10
    what is it?
    CORDIC (for COordinate Rotation DIgital Computer), also known as Volder's algorithm, is a simple and efficient algorithm to calculate hyperbolic and trigonometric functions, typically converging with one digit (or bit) per iteration. It is therefore also a prominent example of digit-by-digit algorithms.
  7. WBahn
    Mar 31, 2012
    18,087
    4,917
    As a rule they aren't that fast -- they only seem fast compared to a human. For cost and power (long battery life) the processors used by calculators tend to run pretty slow and not have a lot of sophistication. They can throw lots of cycles at a problem and still arrive at a solution fast enough that humans think it was near-instantaneous.
    Now, because they ARE slow, the algorithms, such as CORDIC, that have been used have been carefully developed and optimized for performance on resource starved platforms (limited clock speed, limited memory, limited instruction set).
    An adder is just what the name implies -- it's a circuit (digital in this context) circuit that takes two inputs, adds them together, and produces the result as its output. Lots of ways to implement an adder depending on what is important in a particular application -- speed, size, cost, simplicity, ....
  8. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Adder circuit is reverse of subtraction circuit. In fact electronic calculator is quite slow. normally ASIC built around some cpu core.
    RRavi likes this.
  9. WBahn
    Mar 31, 2012
    18,087
    4,917
    Now RRitesh, what is the point of just posting the first couple of sentences from a Wikipedia article when you are asked a question. Clearly it is not because you understand what you have posted -- or at least never has been so far.
    absf, jpanhalt and recklessrog like this.
  10. jpanhalt
    Jan 18, 2008
    5,699
    909
    @WBahn Glad you said it, not me. I suspect Billy Mayo's cousin may be around too.
    John
  11. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    waitforitmodsareonit
  12. RRavi
    May 4, 2016
    10
    does adder mean?
    2+5 =7 ??
    can we do this we digital I.C.?
  13. odm4286
    Sep 20, 2009
    155
    5
    Eh I'm pretty sure its PFM
    recklessrog likes this.
  14. RRavi
    May 4, 2016
    10
    I mean in binary
    00=0
    01=1
    10=2
    11=3
  15. RRavi
    May 4, 2016
    10
    What this mean?
Thread Status:
