You need a resistor in series with each switch to give a delay ( a pot in series with a resistor if you want to adjust the delay). As shown, the delay is determined only by the switch and supply resistances.First try!.....................
Also, if you add a 20V or so zener in series with the SSR input (anode to input) then you can get the desired delay with a smaller capacitor.
