How are the wires connected to this connector?
Discussion in 'General Electronics Chat' started by spinnaker, Oct 3, 2010.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,065
    1,176
    Is some kind of special crimping tool required?
  2. R!f@@
    Apr 2, 2009
    8,787
    771
    Na!!..All u need is a cutting plier and a flat nose plier to crimp and connect wires to them.
    Quite easy from the way I see it
  3. spinnaker
    Oct 29, 2009
    5,065
    1,176
    Thanks I think I will grab them.
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    It is an IDC (insulation dislacement) connector. No crimping is required (contrary to Rifaa). Cut the wires square. Press them into the top with any convenient tool You can use a screwdriver, if you are careful. Note that the "blades" on the sides of the V into which you press the wire make the contact.
    John
  5. spinnaker
    Oct 29, 2009
    5,065
    1,176
    Thanks John.
  6. R!f@@
    Apr 2, 2009
    8,787
    771
    Hell ya...John's right, but I did have a crimper for those types of IDC. Hence the word "crimp" surfaced.
    Even a newbie can do it with pointed knife cutter.
