Hotel Access
Discussion in 'The Projects Forum' started by drchris, Apr 19, 2010.
  1. drchris
    Apr 4, 2010
    i try to fix a module to deactivate the hotel's room airconditioner after 30sec of the opening of the door. I got a magnetic contact in the door and i need to give a N/O contact to the air conditioner technician not through a relay but through an optocoupler. Any ideas please??? Thank you
  2. R!f@@
    Apr 2, 2009
    8,787
    771
    this is not simple as you think.
    you need to show us your AC connection terminals and a brief description of what you want to do.
    Modifying or adding circuits to an already operating equipment are not for beginners.
  3. drchris
    Apr 4, 2010
    I placed the alarm security system. The A/C technician needs only a N/O contact without wiring connection(but through the optocoupler) from the magnetic contact of the door. Our project is till there, the connection of this is not our business.
    I just need to open the contact after a few seconds of opening the door.
  4. R!f@@
    Apr 2, 2009
    8,787
    771
    for that you will need the circuit diagram
    But for me the circuit board is all I need to do it.
  5. retched
    Dec 5, 2009
    5,201
    313
    You can use a delay-on-break relay.
    You can send a small signal through your door contact. When the signal is broken (if its NC and the door is opened) it will break the connection to rhe delay-on-break relay.
    The relay will count the amount of time you set then kill the AC.
    http://www.airotronics.com/site/timing_delaybreak.php
    the relay can operate an optocoupler, but I am confused why you need the opto. The relay I linked to has 100% load isolation.
  6. eblc1388
    Nov 28, 2008
    1,542
    102
    Personally I think the timing should be implemented by the A/C guy on his side.
    You just give him the current opened/closed status of the door and he decides when to turn on/off the A/C.
    Come to think of it, problems or fault in the security system or wiring could result in rapid closed/opened status and rely on this signal to turn On/Off the A/C will damage the A/C. The onus is on the A/C circuitry to prevent such condition from damaging his equipment.
