Hi everyone,
I have this question with respect to hot versus neutral wires with AC electricity in household wiring. This is very basic, but if someone could it explain it to me, I would be grateful.
Let's say that you are installing a switch in your house (for example, a light switch). I understand that you are supposed to attach the hot wire -- the one that carries the current -- to the bronze terminal screws. Typically, in the United States, that wire is black.
And the reason that you do this is so that, when the switch is open (off), no current is going to the device (the light bulb in this case).
But here is what I don't understand.
In AC electricity, the direction of current flow keeps changing -- half of the time the current flows in the wire one way, and the half of the time the current flows the other way, right?
So how can we say that one wire is hot (and supplies the current) and that the other wire is neutral (and returns the current)? Why aren't both wires hot half of the time, and both wires neutral half of the time.
Thank you very much.
Stanly
Stanly
