I would make short adapting extensions with XLR male+female connectors. And those to be used as disconnect/connect without shorting.
The audio jack/plug will always stay inserted. The probe cable connector will have then, a XLR plug/jack. No alterations to your original equipment.
probecable----------------------connector-->>--connector-------XLRm---->>----XLRf------connector-->>panel connector
"Connectors" are your current audio type. Blue are the adapting short extensions. Red is now the troubling connection.
There is also miniature XLR if preferred.
Both sizes ----> http://www.kvconnection.com/v/vspfiles/photos/K-X3MMX3M-15-2.jpg
Solved ?
Solved ?
