See the attached pic,
It took me Hrs to solder and desolder, and in the end the IC exploded, literally, with a "POP" , and landed else where, not my face, thank god.
I was thinking about it and I came with a small hot plate idea since the TCON board is a single sided surface mount pcb.
My hot plate will be around an inch each side. I can heat it up to 260°C with a temperature controller. It would make a whole easier to pick up and place the chip without blowing it up and flipping away the adjacent components, right ?
I like to know how I can go about it. Say should I use nichrome wires
enclosed in cement and glue metal inch square plate . sides can be eclosed in glass.
Or, how about ceramic low value high power resistors bonded a bunch together and encapsulate it with cement or lead. Give it a controlled power to regulate heat at 260°C.
I can just put the little cube under the pcb heat it up. The PCB will be on the plate. Not convection heating.
Or any other ideas from u guys ?
