Hot ground vs Cold ground, what is the difference?
Gdrumm
Joined Aug 29, 2008
684
Reading an article by Jestine Yong, and he said cold ground is chassis ground. I think I get that.
But he referred to hot ground as being different.
Is that what we call neutral?
bwilliams60
Joined Nov 18, 2012
1,442
I too have Jestines Ebook and my interpretation of hot ground is ground provided on the mains side and cold ground is chassis ground or secondary ground. Hope that helps. Hot ground = high voltage side. Cold ground = low voltage side.
MaxHeadRoom
Joined Jul 18, 2013
28,688
Still doesn't make much sense, if this is with reference to a ground reestablished on a transformer secondary, it normally should be directly connected or referenced to the primary side ground.
One of the better books on grounding is the one by Eustace Soares, and is used as an international reference by the IAEI, International Assoc of (Electrical) Inspectors.
Max.
aniculav
Joined Nov 18, 2016
Here is an example of hot/cold ground.
The chassis has a 'hot' ground reference on the primary side and a cold ground reference on
the secondary side of the power supply and the rest of the
chassis.
Regards.
Vlad ANICULAESEI
