This is almost an essential piece of kit, but the prices of good ones may seem prohibitive, so I looked into what makes them tick.
There are basically two types divided by where the air is produced. Some (the cheap ones) have a small fan in the torch, while the better ones have an air pump in the larger base unit.
Spare torches are suprisingly cheap so it looks like a possible DIY project to buy one of these, and supply the air pump, box and control.
The control circuit is the fun part of the project as it is basically a digital oven controller, and a PWM motor control for the air flow.
Boxes are not a problem as I was going to hack one of those aluminium vanity cases that already has a strong handle and sturdy feet. I might even fit an IEC socket to the back and make the torch plug in too, so I can keep both the lead and the torch in the top - nice and tidy!
My main problem seems to be finding a suitable pump. The original ones put out 120L/Min, but aquarium pumps are not near that, balloon pumps and car tyre inflators are too noisy, and I'm having a hard time sourcing one.
So my first question is - does anyone know of an air pump that can put out 120L/min?
A double diaphragm pump seems to be what they use.
I will put up photo's as I go and keep you informed of progress.
Thank you.
Richard.
Thank you.
Richard.
