hose bib switch
Discussion in 'General Electronics Chat' started by 1stfrodo, Jan 5, 2016.
  1. 1stfrodo
    Oct 30, 2015
    22
    hello all !
    I am in the process of making a lamp, steam punk art,
    what I would like to do is use the valve to turn the lamp on/off
    is their a switch, that the handle when screwed in, can press to turn on
    then when unscrewed turn off? thanks for your time ! 8E6B0A73-141D-4040-AE76-775154154729.jpg
  2. mcgyvr
    Oct 15, 2009
    4,785
    973
    Is it a stop valve or a gate valve..
    You "might" be able to get a microswitch in there thats arm is triggered by the in/out movement of the valve stem..
    It would be really tight though and I have no idea how you would get it mechanically mounted in such a small area reliably.
  3. BReeves
    Member
    Nov 24, 2012
    412
    64
    Use a bigger valve for more room. I would think about using a reed switch with a magnet attached in place of or in addition to the washer on the valve. Round magnets are available with a hole in the center for the screw.
  4. Picbuster
    Member
    Dec 2, 2013
    391
    53
    If you get the apart you will see a round disk moving to close or open the pipe depending on rotation direction valve knob.
    Remove the disk and replace it with a micro switch or mount it out site when more space is needed.
  5. 1stfrodo
    Oct 30, 2015
    22
  6. BReeves
    Member
    Nov 24, 2012
    412
    64
    Good photo and exactly what I was suggesting.
  7. 1stfrodo
    Oct 30, 2015
    22
    thought so, just wanted to clarify. my head, its thick, hard, :D
    thanks, appreciate it
  8. Alec_t
    Sep 17, 2013
    5,966
    1,133
    A low profile switch such as this might fit. You'd need to take great care no short to the valve body occurs.
