I have a Horizon Quantum II treadmill which has a motor control board problem. The motor tested ok and the elevation motor is working. With the motor disconnected I am getting around 20v at the terminals, which I presume should be much higher. I have replaced the Power Diode and the SCR. The FET seems to be testing ok and the schoktty diodes are also testing ok. Can anybody help?
