Horizon MCB
Discussion in 'The Projects Forum' started by Floss, Sep 19, 2012.
  1. Floss
    Sep 19, 2012
    Hi All
    I Found this excellent Forum from searching for a solution to this problem .
    I Like to play at repairing things but I'm not a engineer just a hobbyist (and a bad one at that lol)
    I found a thread on this forum about my treadmill motor control board (after lots of googling )
    http://forum.allaboutcircuits.com/showthread.php?t=36571
    My Problem is that the belt stuck a couple of times then just stopped working . When I turn the treadmill on it all seams to light up ok then when I press start I can here a relay "click" and a LED come ON (please see pic LED 1)
    After reading the other post it seems there is a MOSFET /Diode combo that blows and a pair of schochkly Diodes that also blow casing the motor to not work .
    As the MOSFET/DIODE combo control the switching of the relay I assumed they are OK (LED 1 coming ON) so I replaced the 2 Schochkly diodes , Now LED2 was dim before is NOW Bright but still no power to the motor :-(
    Hope All this makes sense, thanks for any assitance
    Reagrds
    Jon
  2. Dodgydave
    Jun 22, 2012
    5,150
    769
    Welcome to Forum,
    can you trace the feed back from the motor and see which components it goes to?
    IE, Reverse engineer the pcb
  3. Floss
    Sep 19, 2012
    Hi
    Thanks for quick reply ,
    I tried doing that but not sure if the PCB is 1 or 2 sided .
    Also just out of interest I do get 20v on the motor line apparently this is the DC bias (according to last thread should vary up to 180v)
  4. Floss
    Sep 19, 2012
    Been trying to map out the circuit from the motor pins as that's the part not getting the correct power , as the attached any use or do I need to do some more learning and start again ?
    Regards
    Jon
  5. Dodgydave
    Jun 22, 2012
    5,150
    769
    Your doing well, can you put the component values on as well please, transistor markings like Buz810 or IN4001 etc...
