I am doing a project using a modular NI DAQ chassis and want to make sure I am not missing anything obvious in regards to applying power.
I have two sensors that need a 24V DC supply, a solenoid (24V DC) and another sensor that needs a 12V DC supply.
I have a 24V DC power supply that I will connect to the +ve and com pins of an 8 channel digital output (DO) module.
(This is the bit I want to check)
I need to connect the solenoid to the (DO) device so that I can turn the supply on and off.
I can connect the two 24V DC sensors directly to the power supply.
I need a voltage regulator to bring the 24V DC supply down to 10V DC.
My thinking is that I connect the system as shown below.
Is it that simple or am I missing something?
