Honeywell IS215t
Discussion in 'The Projects Forum' started by allenpitts, Jun 4, 2011.
  1. allenpitts
    Thread Starter Active Member
    Feb 26, 2011
    77
    7
    Good afternoon All About Circuits,
    Working with motion detectors to activate LED displays. Have worked with
    the Quorum G4567 but I get a lot a false signals and other problems. Found the Honeywell IS215t, which is in the same price range as the G4567 is a bit more reliable and is designed in the USA.
    Tried using the signal from IS215t as a switch as in
    http://www.allenpitts.com/electronics/IS215T/Honeywell_IS215T_d.gif
    but while one of the setups did provide on/off operation it was not as expected.
    So tried using the signal to operate a transistor that would close a circuit as in
    http://www.allenpitts.com/electronics/IS215T/Honeywell_IS215T_c.gif
    Unfortunatley this did not work at all.
    The idea is to substitute a 5 or 12 volt relay for the LED so the relay would operate the other devices, in this case, a LED display.
    Any ideas?
    Thanks.
    Allen in Dallas
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Do you have the datasheet of this honywell part?
    This would give us some insight into the part, so we can give a good advice.
    Bertus
  3. allenpitts
    Feb 26, 2011
    77
    7
    Good afternoon Bertus,
    Sorry. I posted the data sheet on my web site but forgot to include the
    URL.
    http://www.allenpitts.com/electronics/IS215T/IS215T.pdf
    Thanks.
    Allen in Dallas
    PS When I get the IS215T to turn a simple LED circuit on and off the next
    will be to get the IS215T to operate a circuit that will keep the relay
    on for longer than the 'on time' of the alarm which is a couple of seconds.
    Would not a 555 timer be a good for this application?
