Discussion in 'Homework Help' started by kissdadog, Jan 24, 2010.
  1. kissdadog
    Jan 23, 2010
    Design a plc that will turn on pilot light PL5 (O:2/7)when pushbutton PB4 (I:1/0){N.O.} is pressed and released. when PB4 (I:1/0){N.O.} is pressed and released a second time PL5(O:2/7)turns off.When PB4(I:1/0){N.O.} is pressed and released a thrid time PL5(O:2/7) turns on. The pattern must repeat.
    I have tried to do this in the diagram attached but PL5(O:2/7) comes on and off randomly when I press and release PB4 (I:1/0){N.O.}, how can I correct this?
    It is noted that this should work as a voltage divider, where as PB4 (I:1/0){N.O.} is pressed and released twice in order to have the PL5(O:2/7) turn on and off once.
    • PLC.doc
      File size:
      71.5 KB
  2. sgardner025
    Nov 5, 2009
    Here is one way to do it. It's a little lengthy but gets it done. There are other ways to do the same thing. Try to get it done with as few rungs as possible.
