Homework Question (Calculating current by taking charge derivative)
Discussion in 'Homework Help' started by fishguts, Sep 10, 2009.
  1. fishguts
    Sep 3, 2007
    22
    I have a question about the following homework problem.
    The charge enters the positive terminal of an ekement is given by q(t) = -12e^-2t mC. The power delivered to the element is p(t) = 2.4e^3t W. Computer current in the element the voltage across the element and energy delivered to the element in the time 0 < t < 100ms
    I know that current is equal to the derivative of charge
    i = dq(t) / dt
    But when I take the derivative of q(t) i get 24e^-2t which does not give me a constant. Do I plug in 100 ms into 24e^-2t and subtract that from 24e^-2t evaluated at 0?
    Thanks for any help!
  2. mik3
    Feb 4, 2008
    4,846
    63
    Integrate voltage*current between 0s and 100ms to find the energy.
  3. someonesdad
    Jul 7, 2009
    1,585
    141
    What leads you to believe the current should be a constant? Once you have the answer to that, you'll realize you already have the correct answer to the question about the current.
  4. jit26
    Sep 12, 2009
    11
    I am not sure but try this way.
    p(t)=v(t)*i(t)
    p(t)=v(t)*dq(t)/dt
    p(t)*dt=v(t)*dq(t)
    now intergrate t=0 to t=100ms with respect to t. :confused:
    not sure if i am right or wrong.
