Homework Question Arithmetic progression
Discussion in 'Math' started by BrainFog, Jan 24, 2012.
  1. BrainFog
    Jan 24, 2011
    I am currently finishing off my maths homework and I am stuck on one of the last questions.
    "An AP has a common difference of 3. Given the nth term is 32, and the sum of the first n terms is 185, calculate the value of n."
    It is a question from the textbook and I looked up the answer in the back of the book and it is 10. The methods I am using just don't give me the answer 10. Clearly I am missing something.
    I am sure that different countries have different notations.
    I know that Sn=185=(n/2)(2a+(n-1)d) and Un=32=a+(n-1)d and d=3. I substituted in d and rearranged so they both equal a and combined them only to get the wrong answer.
    So what should I have done? Just a quick explanation is needed so I can get the jist of it.
  2. 1chance
    Nov 26, 2011
    I don't understand your Sn equation. I would have started with Sn=(n/2)(first term + nth term) then 185 = (n/2)(first term + 32). Your 2nd equation, nth term= first term +d(n-1) as you stated goes to 32 = first term + 3(n-1). Using substitution to eliminate "first term" will give you an equation in terms of n. See if this helps you.
