homework question #4
Discussion in 'Homework Help' started by cgeorge5150, Oct 8, 2009.
  1. cgeorge5150
    Oct 8, 2009
    9
    determine the value of R2 and the total power dissipated by the load resistors.
    Since Voltage is the same in parallel, I used Ir3 x R3 and got voltage of 108V. Ir1= 108V/15K Ohm = 7.2mA. Itotal = 13.2mA. 13.2mA-2.3mA-7.9mA= 3.7mA. R2= 108V/3.7mA= 29k Ohm. Power is V(squared)/Rtotal. Rtotal= reciprocal of sum of resistors. Power equals 1.4 Watts
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Do the work first then post your answer. We're not a homework service.
  3. cgeorge5150
    Oct 8, 2009
    9
    blue room, wasn't asking for answer, was looking for guidance. So your ideaology that you are the enforcer of this website is not appreciated.
  4. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Guess you didn't read the sticky.
  5. hobbyist
    Distinguished Member
    Aug 10, 2008
    773
    62
    That's the answer I came up with.
    Good job in figuring that out systematically.
    You seem to understand the basic theorems KVL and KCL and ohms law, quite well.
