homework question #3
Discussion in 'Homework Help' started by cgeorge5150, Oct 8, 2009.
  1. cgeorge5150
    Oct 8, 2009
    three identical 12V batteries are connected in parallel across a load which consists of 1.2K Ohm, 2.2K Ohm, and 3.3K Ohm resistors in parallel. that is the value of the current supplied by each?
    I figured that since the batteries are in parallel then my Vtotal is 12V. I used teh reciprocals of the resitors to get Rtotal of 629 Ohm. I got Itotal of 19 milliAmp. I then divided 12V by each resistor. So R1 is 10mA, R2 is 5mA, R3 is 3mA. Which adds up to 18mA.
  2. RiJoRI
    Aug 15, 2007
    "The current supplied by each" -- each battery?
    Solve the equivalent resistance for the three resistors.
    Solve the voltage for the three batteries.
    Apply Ohm's Law.
