homework question #2
Discussion in 'Homework Help' started by cgeorge5150, Oct 8, 2009.
  1. cgeorge5150
    Oct 8, 2009
    9
    what is the value of teh voltage between points X and Z?
    I assumed that since this was a parallel circuit that the answer is the same as the voltage source or 100V
  2. hobbyist
    Distinguished Member
    Aug 10, 2008
    774
    64
    For starters current ONLY flows through a CLOSED loop.
    So what is the voltage drop across X and Y first.?
    And what is the volt. drop across Y and Z?
    You have the right answer but your assumption is not entirely correct.
    If X to Z were closed and Y was disconected than you would have a parrallel circuit.
