Okay, I can see that figuring out the current and using that requires a leap that you aren't quite ready to make -- besides, that leap actually gives you the answer without calculating the current, so it's probably not the best way to go anyway.No, Vab is not equal to Vbatt. So Vab = 5V + Iac*R, but I'm not sure how to calculate that voltage (more specifically, what the current is). My guys would be 0.1 amps, but I'm assuming Ohm's Law
But it let's me make another really valuable point -- namely that you can choose ANY path between two point and sum up the voltage along that path to find the voltage difference between the two points.
So at this point we have that
Vab = Vac + Vca
which gave us
Vab = Vbatt + Iac*R
But we can go the other way, too, namely through the capacitor and over to the battery. If we define Vcap to the the voltage across the capacitor with the positive side on top, the we have that
Vcap = Vb - Va = Vba
Since Vxy = Vx - Vy and since Vyx = Vy - Vx, it stands that Vxy = -Vyx. Hence, in our case,
Vab = -Vab = -Vcap
Like the other equation, this is a general result (with the switch closed) and so is valid at all times (that the switch is closed).
We've previously established that, at t=0, the voltage across the capacitor is 0V. So what is Vab at t=0?
Notice that this let's you find the current very easily, as well. Since both of these equations are valid for all time t>0, we can set them equal:
Vab = Vbatt + Iac*R = -Vcap
Notice that, at t=0, we know Vcap, Vbatt, and R. What does that mean we can do?
The part you were responding to here was my comment regarding your answers to part C, in which you indicated that the current would be 0.1A (but without indicating the direction -- please, please, please always be sure to indicated direction/polarity for an current or any voltage).I'm kind of confused, was I wrong in my answers then? Or the logic
If there is ANY current in a capacitor, can the voltage across that capacitor be constant?
If you answer no, then what does that tell you is required for the case when we are in DC steady state?
