Homework problem: Complete the table for the following sequential circuit.
Discussion in 'Homework Help' started by Gonzalo Armbrust, Jun 28, 2015.
  1. Gonzalo Armbrust
    Jun 28, 2015
    16
    I have to construct a truth table based on the sequential circuit that is given, however i'm incredibly lost as to where to start. ( I have attached a picture of the problem below)
    For these types of problems, am I able to start at any input?For example according to the problem, lets say that A=0, B=0, and =1, if I know that B is set to zero, which then gets negated by the NOT gate to 1, and combined with X ( which equals 1), then the output of the logic gate is 1 ( since the output of the gate negated is 1), does this make the next state of A = 1, and also B = 1, since it would still be 1 through the D circuit?
    OR
    to find the next state value of B, could I just start at A input, and deduce it would be the same value of what A is initially since they are only seperated by a D circuit?
    My biggest question for these types of questions is, what input do I start exactly?
  2. crutschow
    Mar 14, 2008
    13,509
    3,385
    Start with the top of the Truth Table and sequentially solve for each state until you reach the bottom.
  3. Gonzalo Armbrust
    Jun 28, 2015
    16
    I worked through it, and this is the truth table I came up with, is this correct?
  4. tshuck
    Oct 18, 2012
    3,531
    675
    No. Your first row shows that 0 xor 1 is 0.
    Edit: disregard, I mistook the XNOR for XOR.
  5. WBahn
    Mar 31, 2012
    18,089
    4,917
    No need for 1.1 MB files when <22KB will do quite nicely.
    Yes, your truth table is correct.
    Notice that an XNOR gate with one input negated IS an XOR gate.
  6. WBahn
    Mar 31, 2012
    18,089
    4,917
    Huh?
    It shows that, for B=0 and X=0, the (B') XNOR (X) is equal to 0.
  7. tshuck
    Oct 18, 2012
    3,531
    675
    Whoops, my mistake, I didn't realize it was XNOR. That's what I get for trying to check in while in the middle of another task.:oops:
  8. WBahn
    Mar 31, 2012
    18,089
    4,917
    Know the feeling -- I'm a lousy multitasker.
