i am trying to do 2 parts to the questions and i don't know how to do them and here is the question
"Transformer primary winding V1 rms = 110 V 60 Hz and secondary supply same frequency V2rms = 18 V and resistance Load 1000 ohms. diode 1N4005.
1. calculate the peak value of the supply voltage.
2. determine the load current I. for the diodes used, identify from a relevant datasheet the voltage drop on them and their internal resistance for the 1000 ohm load and thus calculate the peak rectified voltage Vp.
