Homework help/:
Discussion in 'Homework Help' started by jacyhui, May 26, 2008.
  1. jacyhui
    May 26, 2008
    MCQs:
    1. What is the disadvantage of using contact brushes in an a.c generator?
    a emf generated is very much reduced
    b heat oss through brushes very high
    c current drawn from the generator would be small
    d sparks will appear at the contact
    2. A step up transformer is used to...
    a low potential energy to high
    b low current to high
    c direct current to alternating
    d low to high power
    3. the primary coil of an ideal step up transformer is connected to a low dc source. what will appear at the secondary coil?
    a high potential energy
    b high potential a.c.
    c no power
    d low current a.c
    4. what is the material used to make the core of an ideal transformer?
    a aluminium
    b iron
    c copper
    d stainless steel
    5 what is true of an ideal step-down transformer?
    a the power of pri coil is teh same as power at sec coil
    b the power is higher the the pri coil
    c the power is higher at the sec coil
    d the power of the sec coil is not dependent on the power at the pri coil
    please help me):
    i missed out a few phy lessons because i was down with some flu.
    so if possible, do offer some explanations with the answer so i can understand:)
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
