**A single phase 50 kVA, 2400/240 volt, 60 Hz distribution transformer is used as a stepdown transformer at the load end of a 2400-volt feeder whose series impedance is 1+j2 ohms. The equivalent series impedance of the transformer is (1+j2.5) ohms referred to the high voltage (primary) side. The transformer is delivering rated load at 0.8 pf lag and at rated secondary voltage. Neglecting the transformer exciting current, deternmine
a.) the voltage at the transformer primary terminals
b.) voltage at the sending end of the feeder
c.) P and Q delivered to the sending end of the feeder..
I need help on this one
1.) What does "The transformer is delivering rated load at 0.8 pf lag and at rated secondary voltage." exactly mean? I understand the pf lag but by "at rated secondary voltage", does it mean that E2 (voltage across the secondary coil is 240? (which in turn tells me that E1 is 2400)
Here are my drawings:
transformer showing both primary and secondary: http://postimg.org/image/5pl47mhq9/
transformer with low referred to high: http://postimg.org/image/i6j4rm4v5/
Are my diagrams drawn as they were supposed to be? Also, are my planned steps correct? First, I will use the pf to solve for current phasor that flows through the load. I can use the fact that the current lags the voltage load by 36.87 degrees, and I'll just set one voltage (maybe VL) as the phasor reference voltage... After this, I can easily solve for the primary voltages and others..Also, about the power supplied at the sending end of the line, does it mean the power delivered to 1+j2? thanks.... Please clear the "sending end of the feeder" confusion...
