Homework - Boolean Simplification
Discussion in 'Homework Help' started by SaadMo, Sep 15, 2014.
  1. SaadMo
    Sep 15, 2014
    Hi guys, I am new to the forums but have benefited from the sites tutorials.
    I have a hw problem: To simplify (a+b+c')(a'b'+c)
    If someone could work it out step by step, how they would do it, I would really appreciate it. What I typically do is take the dual of the function, then start working on the a'+b'c side by using x+x' to make sure all the terms have the variables.
    I end up with a'bc+a'b'c'+ab'c+a'b'c, but I am not sure how to proceed from here, or even if I did the earlier steps correctly.
  2. JoyAm
    Member
    Aug 21, 2014
    112
    Have you considered using a Karnaugh map ? I believe its the best way to solve stuff like that.
    I got a'c+ab'+b'c ( i havent worked on it lately so i may be wrong)
    SaadMo likes this.
  3. MrChips
    Oct 2, 2009
    12,636
    3,455
    multply the terms (a'b'+c) by a, then by b and by c'
    and then simplify the SOP (sums of products).
    Yes, Karnaugh mapping is a very useful tool for simplifying boolean logic. However, it does not help to reduce the expression in this example.
    SaadMo likes this.
  4. dalam
    Member
    Aug 9, 2014
    58
    6
    SaadMo likes this.
  5. SaadMo
    Sep 15, 2014
    Thanks guys, I appreciate the help.
    I actually used a karnaugh map to solve it as that is way easier for me, but the HW required just striaght algebraic manipulation.
    JoyAm likes this.
