homemade solenoid doesn't work
Discussion in 'The Projects Forum' started by Mutad0r, Feb 15, 2011.
  1. Mutad0r
    Apr 6, 2010
    10
    I got it 10 times in 3 layers.. I tried my most powerful power source, but it did nothing. no magnetic field whatsoever...
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    There's probably a field there but a very weak one. How much current are you driving it with?
    How are you sensing the resulting magnetic field?
  3. Adjuster
    Dec 26, 2010
    2,147
    300
    With an air-cored coil of only 30 turns, you may need quite a lot of current to get a noticeable effect. It looks as if you have used quite thick wire with thick insulation; you might get better results using thinner enamelled wire, as you would be able to fit in many more turns into a given space.
    Thinner wire would need to be supported on a former, that is to say a spool so that the windings will stay neatly in place.
  4. wayneh
    Sep 9, 2010
    12,368
    3,224
    If current is flowing, you have a field. Trust me, you have not violated the laws of physics. Try using a compass needle near the open end of the coil.
    Your low gauge wire will short most sources - so you may not have as much current as you think. You could wire a bulb in series to limit current and also indicate that current is flowing.
  5. Bernard
    Aug 7, 2008
    4,231
    414
    Try discharging e 5,ooo uF cap @ 12V into solenoid.
  6. Adjuster
    Dec 26, 2010
    2,147
    300
    Discharging 5000μF into such a low impedance could cause quite a bang. I'm not sure that would be completely safe - bear in mind that the OP may not be an adult.
  7. wayneh
    Sep 9, 2010
    12,368
    3,224
    ...and may not get that opportunity, if he's not more careful. ;)
  8. CDRIVE
    Jul 1, 2008
    2,223
    99
    There are times that replies on AAC can be funnier than a face plant on those "Hey, watch this videos"!:D
  9. Bernard
    Aug 7, 2008
    4,231
    414
    A Bang; more like a little poof.
  10. wayneh
    Sep 9, 2010
    12,368
    3,224
    Hah! That's what SHE said!
  11. thatoneguy
    Feb 19, 2009
    6,357
    718
    The imductance of that inductor will be very low, around 150-300 uH, but with high current handling ability. Guessing on dimensions for that value.
    Can't think right off of an application for it though.
  12. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I'm betting more like 5uH to 15uH, as there is no core.
    Saturation would occur quite rapidly.
    If you ever opened up a manufactured solenoid or relay, you would find LOTS of turns of very fine enameled magnet wire on the coil.
  13. Bernard
    Aug 7, 2008
    4,231
    414
  14. Ron H
    Apr 14, 2005
    7,050
    657
    I don't think it's possible to saturate an air core coil.
