Homemade Inductors
Discussion in 'The Projects Forum' started by Andy Larson, May 3, 2015.
  1. Andy Larson
    Mar 26, 2015
    51
    I have a small stick of ferrite from a radio coil (I destroyed the orginal coil along time ago), two ferrite bead and two coils of magnet wire on plastic spools on a nail. I want to turn those in to homemade inductors, and possibly variable inductors. I know how to make inductors, ish. Please help
  2. ericgibbs
    Jan 29, 2010
    2,599
    394
  3. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    they are cheap and you'd not know the ferrite material.
    nails are only good for very low freqency or DC
  4. Søren
    Sep 2, 2006
    472
    28
    It's very unclear what you want help with?
    If you wrap a single loop of wire (or even much less than a single mm of straight wire), you'll have a homemade inductance.
    Any PCB is brimfull of (unwanted mostly) parasitic inductance.
    A single turn of wire, with the rod moving from some short distance away to having the single turn coil at the middle of it, will be a variable inductance and is thus a correct answer to your question as asked :p
    But, I'm sure that wasn't what you wanted to hear, so what is it that you want?
    What values or range of values do you want to end up with?
    What's the end goal?
