Homemade CD reader/writer
Discussion in 'The Projects Forum' started by B01011101, Aug 8, 2011.
  1. B01011101
    Aug 8, 2011
    Hi guys, is it possible to create a CD reader/writer at home?
    I think it maybe is possible but I want to ask first, just in case of hazards.
  2. wayneh
    Sep 9, 2010
    12,382
    3,239
    Possible? Of course. Practical? Not even close. Why would you want to build something so complex that you can buy for next to nothing?
    B01011101 likes this.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Not unless you have plenty of ability in precision machining, expertise in lasers, control circuitry, etc. - it's really not worth doing something like that, because you can buy one for around $20 USD nowadays.
  4. B01011101
    Aug 8, 2011
    Well, not supposed to be a practical project but I was thinking of making one for a science fair. By the way thanks!
  5. atferrari
    Jan 6, 2004
    2,664
    784
    Ok. If you start it, maybe your grand son will be able to show it at that fair in 20 years time.
    Is this a troll?
  6. #12
    Nov 30, 2010
    16,685
    7,323
    Sometimes it's hard to tell the difference.
  7. wayneh
    Sep 9, 2010
    12,382
    3,239
    So, would extremely low density data accomplish the goal? I mean, if you could just put a few bits on the disc, would that be acceptable? I could see having a chance if you could aim a laser to within, say, a half inch block on the disk as a single bit. It would still be a BIG project to achieve that mechanical accuracy, and make all the laser control circuits. Merely hard instead of nearly impossible.
  8. debjit625
    Apr 17, 2010
    790
    186
    If you mean ,that you want to make the CD drive mechanism ,then I am sorry you can't because that kind of work is not done by humans its rather done by machines.
    But if you mean that you will buy the CD drive mechanism which are available very easily, and want to built the driver read/write circuits then its very much possible, and it has been done many times you can search google for it.
    I did one mp3 player using my old PC CD drive,you just need to know how to work with microcontrollers. Its just about programming the correct protocols.
    Just don't look at the laser.
    Good Luck
  9. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    If you can't help why you give negative feedback to OP...??
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, such a project would involve the use of IR lasers that exceed the limit of safety for items such as laser pointers, etc. As such, that would place the project in a "hazardous" category, which also puts the project beyond the scope of the forums.
    You could put an eye out with that!
    But seriously, you wouldn't be able to see the laser light with the naked eye, so you wouldn't know for sure whether you were being exposed to it.
    Also, the project would have to be completely enclosed in an opaque material (like steel) so that the laser light couldn't escape. This limits the usefulness of the project from a science fair aspect as the viewers would not be able to see the "inner workings" of the device.
  11. B01011101
    Aug 8, 2011
    Wow, I didn't think of that. Thanks for your information.
