homemade battery powered usb supply
Discussion in 'The Projects Forum' started by lokeycmos, Dec 2, 2011.
  1. lokeycmos
    Thread Starter Active Member
    Apr 3, 2009
    432
    7
    hello, i just got a bright idea the other day. i want to make a portable battery powered USB supply to power my friends E-Cigarrette on the go. i drew up a quick schematic, just need some critiques before i build it. it looks right to me, but would like your opinion before i put it together. ty
      File size:
      166 KB
      19
  2. wayneh
    Sep 9, 2010
    12,371
    3,224
    That'll work, but realize that 4/9 of what the battery supplies will be burnt off as heat, and that a 9V battery just doesn't have much juice to begin with. Under much load at all, it won't even be able to hold 5V at the output because there's some drop across the regulator itself and the battery will be pulled down to 7V or below. You might consider 4 AAs and drop the regulator, or use a 12v supply in the car.
  3. lokeycmos
    Apr 3, 2009
    432
    7
    ooohh. how much drop are we talking across the regulator?
  4. wayneh
    Sep 9, 2010
    12,371
    3,224
    The datasheet says it needs 7.2v minimum to maintain regulation at 0.5A. At 0.5A, the 9V battery will not supply 7.2v.
    On the upside, I don't think you need the capacitors when battery-operated.
  5. tracecom
    Apr 16, 2010
    3,878
    1,396
    Three AA or AAA batteries in series will do the job without any other components except the USB jack. And they will last a lot longer than a standard 9V battery.
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    Cool Solution
    She created the "Minty Boost" boost converter about 3 or 4 years ago, and now it's almost a household name.
    Duracell and Energizer have even put out clones.
  7. lokeycmos
    Apr 3, 2009
    432
    7
  8. thatoneguy
    Feb 19, 2009
    6,357
    718
    Yes, it makes the schematic a little easier to follow simply noting frequently used common lines (if done properly).
    Circuit board is only $5, so if you order that and the switching IC, it would save a lot of time. Though you could order the switching IC and the rest of the stuff needed at the same time you get parts for your amp and save a lot on shipping as well.
