Home work help!!!
Discussion in 'Homework Help' started by r1man01, Feb 6, 2012.
  1. r1man01
    Feb 6, 2012
    I need help desinging this circuit on paper so that I can build it in multisim and on a bread board for my digital circuit class. Please let me know if you can help out. I have attached a description of my circuit that i have to build for my lab home work.
    Thanks!
    kris
    <snip>
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    Okay, you have provided enough info for your problem, but we will need to see an effort towards the solution from your part, before we begin to help you.
    Post any work you have done so far.
  3. r1man01
    Feb 6, 2012
    If I new how to build the circuit I wouldn't be asking for help or posting on this website. I'm still trying to figure the problem out as we speak.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Okay, let's start from the first question.
    Can you implement a circuit that will "recognize" the number 5 (binary 0101), using logic gates, and output a HIGH (1) in that case?
    I think it's pretty basic.
  5. BillO
    Distinguished Member
    Nov 24, 2008
    985
    136
    Here is a hint.
    (LSB to the right)
    Since 5 = 0101
    and 9 =1001
    They both have two high bits and two low bits. Exactly the same circuit will work for both, you just have to re-arrange the inputs.;)
    r1man01 likes this.
  6. r1man01
    Feb 6, 2012
    Thanks, i'n trying to get it to work in multisim. Thanks for the hint
  7. BillO
    Nov 24, 2008
    985
    136
    Good,
    If you can't get it to work, post what you tried and we'll help.
  8. BillO
    Nov 24, 2008
    985
    136
    I guess you got it to work?
    With 5=0101 (DCBA)
    Did you get A and C and not( B or D)?
    Implement with a 3 input AND gate, and a NOR gate.
    For 9, swap D and C.
