Home work help
Discussion in 'Homework Help' started by Webby, Sep 6, 2008.
  1. Webby
    Thread Starter Active Member
    Jun 15, 2008
    66
    Hi, Ive been given a home work quiz for the week end, the circuit consists of a...
    12V battery
    some wires
    4 5pin relays
    1two way switch
    2 electric fan motors DC
    The question is to connect and design a circuit with the above components the fan motors must be able to blow as well as draw in air (reversed pollarity).
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Give it try yourself and then post a diagram of your circuit. Then we can assist you if you need any heip?
    hgmjr
