Home made level shifter help
Discussion in 'The Projects Forum' started by snoop, Nov 1, 2009.
  1. snoop
    Sep 27, 2009
    I am trying to connect a 5 volt serial GPS that I have to my router. My router has serial port on it that runs on 3.3 volts. I need to build a level shifter that can communicate to it. Heres the basic setup below.
    I saw some directions on there internet for building a level shifter so the router can communicate to a computer but i believe that is 12volts. Here is the basic diagram.
    I am a complete novice to all of this. Would it be hard to adjust the circuit above to 5v instead of 12v?
  2. Boo
    Member
    Oct 27, 2009
    40
    I'm pretty sure what you will want is a simple voltage divider using resistors...to get 5 to 3.3V
  3. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    There is a long discussion of this on the piclist.com. Search the forum there. One method is using transistors, another is voltage divider, another is logic IC that have compatible in/out ......
  4. t06afre
    May 11, 2009
    5,939
    1,222
    If both ports are RS232 compatible you may route the signal direct. On the other hand if not. You may use a max232 type circuit as level translator. That is if one of the ports is of RS232 type and the other is not that kind. If both is not of RS232 type build your own level translator.
