Home made 5 pf trimmer capacitor
Discussion in 'The Projects Forum' started by joemayer, May 26, 2013.
  1. joemayer
    May 26, 2013
    I am in need of a 5 pf trimmer cap and was thinking whether it would be possible to make one from small washers and mica?
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    Make a gimmick capacitor by twisting two pieces of ordinary hookup wire.
  3. crutschow
    Mar 14, 2008
    13,472
    3,359
    Typically you get 2-3pF/inch of twisted wire that way.
    absf and #12 like this.
  4. atferrari
    Jan 6, 2004
    2,663
    783
    Length matters
  5. ErnieM
    Apr 24, 2011
    7,434
    1,625
    As does using insulated wire. ;)
  6. Shagas
    May 13, 2013
    802
    74
    won't that make a mini inductor?
  7. LDC3
    Apr 27, 2013
    920
    160
    No, because the wires are not connected together. There is a very large resistance between the wires, just like a capacitor.
  8. crutschow
    Mar 14, 2008
    13,472
    3,359
    No. You use two separate pieces of insulated wire twisted together. No connection between them. It's a simple two-plate capacitor with the wires being the plates.
  9. joemayer
    May 26, 2013
    Thank for responding guys. I need the 5 pf trimmer to offset the vfo of my QRP cw transceiver about 1 kHz below the transmit frequency on receive, I wonder if the twisted hookup wire will do the job?
  10. crutschow
    Mar 14, 2008
    13,472
    3,359
    We've given you the info. I suggest you give it a try and let us know if it works. You shorten it and change the twist to tweak the value. Start with a longer wire then you think you need and keep snipping off a short piece of the ends until you get the right value.
  11. atferrari
    Jan 6, 2004
    2,663
    783
    Few weeks ago I did that with a pair of tightly twisted wires.
    If I recall right, 8 cm measured 8pF. After pruning it little by little I found the relationship to stay quite consistent down to the last 2 cm.
    I wonder how stable the actual value could be. Besides temperature, what else could ruin the value?
  12. LDC3
    Apr 27, 2013
    920
    160
    Degradation of the insulation; although that may take several years.
  13. crutschow
    Mar 14, 2008
    13,472
    3,359
    If you use wire with teflon insulation, the value will likely be stable for the life of the equipment.
  14. edwardholmes91
    Member
    Feb 25, 2013
    200
    20
    I personally think it would be easier to buy one
  15. GopherT
    Nov 23, 2012
    6,300
    4,020
    Unfortunately, the OP doesn't know exactly what value he needs but is likely somewhere near 5pF and the wants to adjust/ tune his circuit. The lowest value is 3.5pF and, after soldering, may be outside the range the OP needs. The twisted pair method can be used for very fine tuning. Wires with varying thickness insulation can be used for varying degrees of control.
  16. edwardholmes91
    Member
    Feb 25, 2013
    200
    20
    Fair do's, the link I posted though had ones down to 1.5pF ;)
